1 - 16 of 16 Posts
· Registered
hi
i hv just try to install a new pickguard on my squier strat
its both a 8hole pickguard
but after i got everythign from one pickguard to another....i found that the holes are not in the exact place....and i only manage to screw back 4 of the 8 screws...
any suggestions of waht i shud do??.....re drill the hole or just leave it as it is??
also...just a side question...i found the 12th fret at high E start to buzz on bends...after installin the pickguard...will a normal setup at a guitar tech will fix it?
thx
· Registered
Discussion Starter · #4 ·
Ibateur said:
Re the "holes left empty" what I would do is cut a couple of screws and glue them in place to preserve the visibility.
Re the buzz, yes a setup will normally fix it, though the setup could require fretwork.
thats a gd idea..but doesnt the pickguard come lose or anything?
i dun think the buzz happen before i replace the pickguard....do u think theres anythign to do with the unbalance tension on the neck?..caz i just losen all the strings
· Registered
OR ... look for those non-pre-drilled pickguards and match them up then transfer all the electronics from one guard to the new one. Maybe you can trade in the other "new" one at the store.
I recently bought a mighty-mite pre-wired pickguard, thinking that "all strat dimensions are the same". Boy was I wrong. Since the body was a ply-wood poS, I drilled new holes. It sure didn't look pretty.
If the holes are mis-aligned but will reach the original holes, I would NOT even try. You'd end up with ovalled holes.
You could also try the link up there (pickguard paradise) and find out what your options are (for a price)...
Good luck!
· Registered
Same thing happened with my strat... so I brought my original pickguard with me the second time to buy one that fit.
Also happened on my VWH... the mirrored guard doesn't line up all the holes perfectly... so I just left them out. It stays in place just fine... no one ever notices.
· Registered
Discussion Starter · #11 ·
Good luck!
i got myself a Anodized gold pickguard ...damn it didnt fit..i guess i can now go around and match a pcikguard up now with the one taken off...an actual fender anodized gold cost a fortune and they look the same
· Registered
Discussion Starter · #12 ·
shredfreak said:
I screwed only about 5 screws. Same thing usually on those replacement pickguards but even with only 5 screws the pickguard doesn't fall off.
what i m worry is that theres only 1 screw on the top side of the pickguard
(in playin position..) while the 2 screws in the middle bottom side fits....and one screw on the bottom side towards the switch
i m just worry the pickguard doenst get a balance support and rips the wood out whn i strat playin heavily n swinging the guitar and moving around
· Registered
it's quite simple really:
some stratpickguards have 7 or 8 holes and some have 11 or 12. If you change one pickguard for the other only 4 or 5holes will line up and one hole (neard the tone knobs) will not fit.
There's only one solution basically; drill holes or the guard won't be in place properly. You'll risk messing up your wires and/or pickups whilst moving about...
good luck!
· Registered
sugizo_esp said:
hi
thx
Maybe this suggestion is a bit expensive since it is squire but you could go to Pickguard Paradise :) (banner above).
Regards
André
1 - 16 of 16 Posts
