1 - 20 of 29 Posts
· Registered
Just testing the fix for the image posting problem and seeing if we can get a new thread going as it's quiet here.
Idea: post a shot of your current Pedalboard and let us know why you like it etc.
Mine:
- Whammy IV because I've been having a bit of a buckethead phase..
- Crybaby
- cheapo tuner
- Boss compressor
- Behringer Tubescreamer clone (I back the gain off quite a bit and this is a really neat clean boost)
- Marshall Jackhammer as a distortion for dirty (hate it, think this gets swapped out for a good fuzz pedalsoon)
- tremelo (usually my Voodoo Labs one, but currently a generic replacement while i fix a loose connection on the good one)
- Boss DD6
- Looper
Pros: really versatile rig
Cons: limited dirty sound. I'm thinking it needs a better replacement for the Marshall pedal. Probably a small enclosure Big Muff reissue...
Any recommendations?
Lately I play lots of buckethead, Floyd and satch covers and the odd post rock style ambient thing with a JS1000 into a sh*ty solid state Marshall.
· Registered
I call it my glorified pallet, I'm a forklift mechanic, so it's my kind of humor :nerd:
It's a lot of pedals... that's what I am told anyway
Tuner - cuz I hate the clip on tuners
Cali 76 compressor, cuz ya gotta play some funk
Digitech Drop - Cuz your cover band wants to play barracuda but no man except Robert Plant can sing it in standard tuning
Boss PH-1 Phaser - cuz Analog is king, and you can't play any Van Halen without one
Boss BF-3 Flanger - ...oooo Barracuda
Tone city Fuxx Fuz - It's cheap, small, and sounds like hendrix
Tone city Angel wing Chorus - We play some Police and it's also small
Boss DD-3 - It's good enough and I am too cheap to buy a DD-7
Boss RV-6 - Can't play classic rock without reverb
Morely Volume Plus - Because if you run a volume pedal in the effects loop, it can be a boost pedal
Cry Baby Jerry Cantrell Wah - Sounds nice and dark, plus it has a voicing knob, so that's cool :D.
I wish I had a whammy pedal! I'd have to build a bigger board though, and... It's already heavy.
Pros: It has it's own internal Voodoo Lab power supply and is SUPER quiet.
Cons: I am running out of room 8O
· Registered
Discussion Starter · #4 ·
When I'm gigging rather than just a practice/jam session rig then i always throw a volume pedal in too. Makes balancing everything out with everyone else so much less fiddly too if you're playing little venues without a good sound guy.
I'd have the purple flanger too if I had space. Because... we used to do a lot of Cure covers. I think Robert Smith uses that model a lot.
· Registered
if you are looking for a fairly inexpensive but awesome sounding gain pedal, I saw on Andertons music stores youtube channel a pedal called golden plexi. It's a tone city pedal and sounds REALLY good. I don't use any distortion or OD pedals because I have a high gain amp. But that little thing is impressive. I think it's like $50 or $60.
· Registered
Discussion Starter · #6 ·
wow that's cheap. I'll see if anywhere local stocks. Plus it's tiny so it's gonna fit 😀
· Registered
Soooo.... Not trying to de-rail this thread, but... a drop tune pedal? Until now I thought I needed a lot of guitars, since changing tunings on floating bridge guitars is such a pain. How do you like the way it works? I watched a youtube video and the dude really liked it, seemed to sound good too.
BTW - What kind of Ibanez is that guy using? Obviously a Vai signature, only way cooler than most!!
· Registered
I love the thing. It sounds really nice, it's not buggy sounding, but it is a power hog. It needs at least a constant 250mA power supply, otherwise it buzzes a bit. So if you're using a daisy chain, it can cause some noise. We also cover no one knows from queens of the stone age. It's in C standard tuning.
When i am practicing at home i sometimes use it to be a full octive lower to loop a bass line in my loops when i use my ditto pedal, which isn't on that board.
· Registered
Discussion Starter · #9 ·
I got round to dusting off my whammy pedal and playing with using it to drop tune rather then shift up. Something I'd been meaning to try after reading this.
I wouldn't play a whole song like that. Maybe the drop pedal works better.
But what I did find was great was using it when looping to play Cure songs.
Robert Smith plays those melody lines on a fender bass 6. Suddenly I realised I can copy them pretty effectively on my JS with just a little whammy work!
· Registered
This, running through an EVH 5150III EL34 head. Any sound I want, love it.
Well, don't have my pic saved with a link, sooooo
Korg Pitchblack Tuner
Xotic Mini red Wah
EarthQuaker Devices The Warden Compressor (thanks Chon)
Decimator G string
Boss DD-7 with seperate tap tempo (thanks Simple Switches)
Line 6 Helix Effects
MXR 10 band EQ
· Registered
Discussion Starter · #11 ·
Xotic Mini red Wah
Decimator G string
MXR 10 band EQ
Looks like a very flexible set up.
There's loads of boutique delays out there nowadays but I still think boss DD6 / DD7 are pretty hard to beat for the money.
· Registered
Discussion Starter · #12 ·
Lockdown isn't good for GAS. But buying more guitars feels extravagant in the current situation so I've been trading pedals in and out...
Upgraded pedal board now a post-rock looping dream.
Added the big Muff & Old Blood Noise Endeavors Dark Star reverb early in the chain. Two loopers. The boss Looper is loaded with samples the 2nd one for the live improv/looping..
Whammy shifting down for bass lines or cello like melodies when used with an eBow...
Volume pedal will double up as an expression pedal for the Darkstar when the TRS Y lead arrives next week..
Lots of fun as the same board will do both experimental stuff and straight up blues rock with equal ease..
· Registered
I believe that is a JEM10th with aftermarket EMG's instead of stock chrome Evo's. Everything is not reflective and shiny which does look kind of cool.
Thanks... Yes, very nice looking guitar. I like the Jem style guitars, but some colors and swirls are just a little too out there for my taste. Love the classy binding on that 10th though.
· Premium Member
I need to get my pedals in order. It's time.
I just ordered a power supply and the 2 pedals I am confident will be on my pedalboard (I need an actual board too) are my H9 and amplifiers footswitch. I tried assembling a pedalboard before but I took it too seriously and was not successful. I failed to put pedals onto a board. This time around will be different because I know why the first board failed. With that said, I will probably need logistical help at some point.
· Registered
As much of a pain as it was, I really miss the days of MIDI-controlled rack-mount gear. Now I have committed to this killer little mini-stack stereo setup and it sounds fantastic; but it won't be nearly as versatile as my old rack was. Pedals just seem to be where things are today if you aren't looking for all-on-one amp-modeling.
This is my current pedal-board.
I won't get into the nuance of why I prefer the old MIDI way of doing things, instead I will just post the amps they sit between. Overdrives and rotos go up front. The signal is then split the to inputs of the amps and then the signal comes back via effects chains for the modulation effects in stereo and back to the effects returns.
It's working out well but that has a lot to do with the fact I don't move this stuff. I just dust it off before I annoy my neighbors with it.
· Registered
Discussion Starter · #17 ·
That looks like a really good set-up.
I hear the hall of fame v2 is incredibly versatile. I've been thinking of getting one as my 2nd reverb at the end of the chain.
If i find the cash once this virus thing is gone I'm planning a bigger board and I think that boss EQ is on my list too.
When i play out I'm usually borrowing an amp so the extra ability to tweak with an on board EQ seems worthwhile.
· Registered
That really is a nice board... and amp setup. I would love to put together a nice board like that, eventually settled on the Boss ME-80 multi-fx pedal in the fx loop of my Blackstar. I did it for simplicity, but there is a sacrifice with being stuck with all Boss effects. I've tried putting a few effects in front of the amp and using the ME-80 in the fx loop just for modulation/time-based effects and it does ok, but I always seem to get noise issues with pedals in front of the amp. How do you guys get around the noise issues when using a lot of pedals in front of the amp?
· Registered
Discussion Starter · #19 ·
I'm running 8-10 pedals straight into the amp. Never had noise issues unless i include my old blue MXR EQ in the chain.
A few tips that helped me. Others will have even better ideas.
1. Largely stick to classic pedal order. Where you stick effects like compressor vs fuzz can make a big difference. (Unless i want noise... Shoegaze style)
2. I've almost always got my volume pedal early in the chain. Just kill or drop the signal when not playing
3. I use less and less gain these days.
4. Humbuckers and an isolated power supply rather than daisychaining from a 9v adapter help..
1 - 20 of 29 Posts
