1 - 12 of 12 Posts
Ok. Listen to this track and you will understand what my problem is. lol. I am told its all in the EQ. I am completly new to this though so I have no idea what to do about this. As you can tell, it is very trebely and after I bounce it, it looses the bass. How do I fix this? I would greatly appreciate any help.
http://www.digitalsoundplanet.com/M embers/000175835_000029338.mp3
It sounds like different guitars (the rythm and lead tracks) are figthing for the same frequenceies. So (and keep in mind im no expert on mixing) but that you need to seperate the frequencies. Sounds decent overall, just lacks clarity (see above) in certain parts.
Your mix sounds mono, here at the studio. this could be a problem. Are your drums coming from rewire? If so are they outputed via a mono or stereo aux? Can the individual sounds be panned within rewire and have you done so?
Same for the guitars, pan rythms to say, 9&3 o'clock and leads and bass guitars slightly off center (leave it for vox).
Sounds like the lead and rythm guitars were recorded using the same amp preset on your POD, not much definition, try different settings, don't be affraid to try something that sounds crappy when soloed. It might fit perfectly in your mix.
Keep in mind I'm listening to an MP3 encoded tune...
Also what sample and bit rate are you using? Use the highest rez possible.
EDIT: BTW, the guitar playing is fantastic.
Cheers
Discussion Starter · #8 ·
My drums are comming from my Dr. Rhythm 770. Im not sure what rewire is. I am very new to pro tools. For how I hooked the 770 up...I put a convertor on the 1/4 cable and into the phones because when I tried just into the mono output, i didnt get any sound. Also...There is the L and R hook up for this output on the 770...is there some kind of cable out there that its a 2 end and then it turns into one? is that what i need for this? I also used the highest settings when I bounced. What I heard was for rythm guitar...have it record twice and pan one all the way left and the other all the way right. Is this true? What is rewire and also...is there some kind of metrenome built into protools? Sorry for being a pain in the ass newb..lol...Thanks alot though. I appreciate this.
If you plugged the left o/p jack then you will not have any sound as the mono signal is fed through the right o/p jack.
Plug the left and right o/p into the Mbox's 2 analog inputs. You will need 2 cables for this, possibly with different connector types.
There is a metronome in Pro-tools, I'm pretty sure. You'll have to read your manual. I use Pro-tools for Post audio, not music (yet).
You should always record with the best resolution possible, not bounce.
Rewire is a virtual synth that is usually included in a bundle of extra apps when you purchase a new Digidesign LE product.
Cheers
Pat
the metronome / click is awful in pro tools. i gave up on that and just record a click track to track one from a drum machine. pro tools is awesome once you get past the couple bugs in the system and issues you are having. just do a lot of reading and researching as you are now, and have fun.
Rewire is not a virtual synth....it's the PropellerHead protocol for connecting sound sources....a virtual cable if you will(integrating MIDI, audio and transport control in one invisible application link)...it will connect your virtual synths to your DAW software for example...that's getting real general but Rewire does not generate sound nor is it playable...
1 - 12 of 12 Posts
