I went with a PAF Pro at the neck, and a Superdistortion at the bridge. Either pickup sounds good on its own, but the real advantage is in modifying the wiring at the switch so that both humbuckers are active in the middle position instead of split coils. Two humbuckers in the middle position offer a lot of tonal variety.
You could go with regular pole spacing on the neck pickup and it would probably be perfect. The strings pass over the F-spaced polepieces on the neck pickup I installed, but not over the center of them. F-spacing is a must for the bridge pickup.
