Re-wiring electronics
1010 Views 4 Replies 4 Participants Last post by  TexicanHippy
Hello
I have no idea how to re wire,
Basically I want to replace all my electronics for new ones,
Firstly my guitar is a Jackson RR, it has a volume, tone and 3 way switch, it has two humbucker pickups.
Secondly where can I buy replacements,
Third how the hell do you re wire them up?
The reason I am replacing all this is because that the ones on there are crap and give me this hissing sound when I try to turn the volume knob up and down slowly.
Impossible for doing that violin sound, tremolo?? is it called.
Cheers
1 - 5 of 5 Posts
you most likely need to just replace the the volume pot..you can get parts from your local music shop...but i think you should just take it in and get a tech to do it all for you...i shouldn't cost to much.
... or clean the pots ... or a bad ground or cold solder joint. You should be able to fix that without changing all of the electronics. Have a tech check it out.
Ok I am a novice so I dont know how to solder or clean the pots.
Cheers
Hey dude, Ibanez puts the schematics on their website. I pretty much used the schematic from a JEM555 to rewire my RG350. I used allparts 'pots', my local shop carries alot of stuff so I was good :)
For some reason my switch was wired opposite than it is for them JEM5
hope I helped!
- Joe
1 - 5 of 5 Posts
