1 - 9 of 9 Posts
Discussion Starter #1
NOTE: This is only for MY personal use. I will not try and duplicate Jem's to sell.
With that said, I'm going to try to make my own Jem. I will be using an Epiphone Explorer (Blegh... I don't like carving into RG's) So first thing's first, strip down everything. Done.
I wanted to try to recreate a Jem 777DY. I will be using the evolution and breed pickups, I got my hands on an Edge Zero bridge, I will try to shave the headstock down to make it look like an Ibanez (this will be interesting...), Clear pickgaurd, Schaller tuners, I also got my hands on some colored plastic knobs, and that's basically it.
This is what I wanted to do (And what I'm asking for help on):
- Route out a single coil pickup cavity
- Add Monkey Grip
- Add a Lion Claw
- Add the swirl paint job (This I just don't get how to do)
- Put in pyramid inlays (like the ones you would see on a UV)
Help please?
Aww hell no.
Still it might be do able.
Most of the things you are trying to do can be found by searching the forum.
Why load the dice against yourself by starting with a body you have to modify so much? - I see it now. You don't want to carve up an RG.
I guess I went blind when you said you wanted to create a JEM out of an Epi Explorer.
I am assuming now that this is a joke.
1 - 9 of 9 Posts
