1 - 15 of 15 Posts
Hi all.
I just got myself a 89' 540P-II which seems like it has never ever been cleaned before. Behold the crud:
I am using Rich's cleaning guide, and by using a base for warhammer miniatures, I've killed the worst crud. However, there is still long way to go:
I wonder: Will my 0000 steelwool be enough to do the job (especially on the edges of the frets), or should I look into some nasty chemicals before I get busy with the steelwool?
Also, is linseed oil a decent oil to apply to a fretboard, or should I hold my horses and get some specially made stuff?
Thanks in advance.
EDIT: Should I watch out when steelwooling around the sharktooths?
EDIT2: The reason why I'm asking is because the fingerboard has some deep pores, and they are of course filled with crust. I wonder if I should steelwool all the way into the first level of pores which hold this crust in order to get it cleaned properly, or leave a little tiny bit of crust to be gentle on the fretboard (and for good luck).
If you do use steel wool, either remove the neck or tape up your pickups cause those things are like magnets to steel wool :).
Discussion Starter · #4 ·
Ayrton: Unfortunatly, that doesn't seem to be able to deal with really nasty crud - it's fine for removing steelwool, though.
moebius: Whoa, thanks man! Has to be the most work-saving tip I've had today, I taped my pickups within an instant of reading it. Phew.
I use Synthetic fine steel wool.
Rub with the grain, then oil and wipe down (I use wonderwipes with lemonoil.)
Then I wipe with the wool again. Then another wiping with Wonderwipes, let it dry to a haze, then wipe off.
Use the edge of a pick to get all the heavy stuff off. The rest will soften with oil and just wipe off.
Never continually steel wool a fretbord to clean it, unless you want a scalloped board at some point.
Never do it on the guitar without some serious masking, in fact, just don't do it on the guitar if you do.
Discussion Starter · #9 ·
Whoa, I've been just about to cause a minor catastrophe on myself then, it seems.
I had the idea that the crud would just mix with the oil and sink into the wood, but apparantly I was wrong.
I already spent a lot of energy on rubbing the board, but mostly with a pick/piece of plastic, so the harm is very limited. And luckily, it seems that this was also the first time it ever happened to the guitar, so I guess it can take it just for once.
Seems like I misunderstood the purpose of steelwooling in your Grunge-off, Rich, thanks for putting it straight to me.
I guess I'll just pop to bed and let the guitar rest so that I can wake up to get some good oil tomorrow. Cheers to you all.
1 - 15 of 15 Posts
