1 - 3 of 3 Posts
I agree with 3 bolt, you can't tell until the bridge is on and the strings are under tension. The inserts for your studs should bottom out into the hole though. Then the studs can adjust up or down. Unless you have a wood screw type like the original Floyd rose bridges were. That does seem to be the case though.
1 - 3 of 3 Posts
