This brings up an interesting question. Should I stick with the PAF Pro and FRED? Mind you, my Satch fandom goes back to when I was like 7 and Blue Dream came out. Those are the pickups I grew up knowing Satch used.There's a noticeable difference in the neck pickup for me. I loved the paf Joe. The satch track is close but still isn't quite the same. Especially coil tapped.
I agree with you on the satchur8, it took a bit to grow on me. But I found I liked it a lot more when I lowered it. It had to be a bit lower than my guitars with the mo Joe. It just drives the preamp noticeably harder, especially with clean channels. But once I found my preferred height I actually loved it.I have JS guitars with all combinations pretty much FRED PAf Pro, FRED PAF Joe, Mo'Joe PAF Joe, Satch Track Mo'Joe, Satur8 sustainiac. I think that they are all good. can't say one is clearly better but I do really like Mo'Joe PAF Joe a lot. I don't think you'll be disappointed with any of them. My least favorite is Satur8, but I got used to it
Rich from Ibanez Rules ended up getting me a nut from a JS100, which mount through the back of the neck. But the height is proving to be an issue. I need some shims to raise the action towards the nut.What Locking nut did you find to replace the original one with? I have the same year Js1000 and cant find a new nut.
I'm sure there's folks who will help with the refinish, depending on where you're located going local might be best. I just Google or look on Facebook for them as well as get a sense of who does good work. If you're unable to find anyone I'm happy to help, but with the caveat I'm just a guy with a day job who does this on nights and weekends.Sorry for the lack of updates guys. Not much to report. My refinish had to be delayed due to COVID. I am open to suggestions on who could handle such a job, if anyone has any recommendations.
It was Rich who recommended the JS100 nut. In fairness, the radius isn't really an issue. It's the height that is the problem. So I need to get some of the individual shims per side, due to the placement of the JS1000's truss rod adjustment bolt. A standard flat-bottomed nut won't fit on the JS1000 neck due to the bolt being raised in the center. The JS nuts accommodate for this. So, I just need to get those shims and I'll be ok. $10 shipping on a $5 set of shims from Stew-Mac though. That's criminal. So I'll have to wait until there's some other things I need so I can bundle that shipping.That's weird because a js100 has a 17" radius finger board where a 1000 has a 10" radius. Schaller offers a 10" radius nut... But you'd still have the problem with it being a rear mount... And it is completely flat on the bottom. Rich is definitely your best bet for a genuine ibanez js nut. He can get Everything else, I imagine he'd be able to order you a nut for like... A js24xx series neck, I would think they were pretty much the same, I could be wrong of course.
I've had a problem with the nut sitting too high with the past 2 custom necks I've had made. I used a perfectly flat sanding block and 80 grit sand paper to carefully sand it down flat. It's tedious, and If you're not carful you can sand it at an angle. But I've never had a better shimmed nut on a guitar. If you just need to shim it higher, gotoh offers shim made of brass with their replacement nuts (their nuts are a 14" radius btw). You may be able to find them. I'm pretty sure stewmac sells floyd nut shim.
I've casually done the research and ultimately I don't know who to trust for a complete refinish job. The guy I used previous I trust implicitly as he works for a major guitar manufacturer and his work is what is sold to customers on their multi-thousand dollar guitars. Unfortunately, his schedule doesn't allow for side jobs anymore. That may change down the road, it may not. Hence why I was looking for someone else. But again, it's a trust thing. I've been burned before on refinishes. So for something like this, I really need to know the person doing the job knows what they're doing and will do the job right.I'm sure there's folks who will help with the refinish, depending on where you're located going local might be best. I just Google or look on Facebook for them as well as get a sense of who does good work. If you're unable to find anyone I'm happy to help, but with the caveat I'm just a guy with a day job who does this on nights and weekends. :smile:
No worries man, I'm completely with you on that. Yeah, I can't compete with your guy, just a "medium" amateur for now. 8)I've casually done the research and ultimately I don't know who to trust for a complete refinish job. The guy I used previous I trust implicitly as he works for a major guitar manufacturer and his work is what is sold to customers on their multi-thousand dollar guitars. Unfortunately, his schedule doesn't allow for side jobs anymore. That may change down the road, it may not. Hence why I was looking for someone else. But again, it's a trust thing. I've been burned before on refinishes. So for something like this, I really need to know the person doing the job knows what they're doing and will do the job right.
