Hi all,
I got an RGA72 ~6 months ago, I'm still dead chuffed with it, but the pickups (Ibanez CAP LZ-10/20) are definitely muddier than those in my RG and the Evolutions in my sold JEM555, so it's time to replace
This is my first guitar with active pickups and an active on-board pre-amp EQ though, and I'm not too clued up on wiring in new pickups anyway, so I have a few questions to make sure I'm not overlooking anything before I bust out the soldering iron.
I only stumbled on the info recently that active pickups usually use ~25k pots instead of 500k, and on checking the back of the pot sure enough there's a "25kΩ" marking, so I'm ordering a DiMarzio 1000k pot (yeah twice normal, but I believe this is what the JEM has(?) and I loved the roll-off of the volume on that).
So since I almost overlooked that important detail, what else may I be missing? Would I be able to wire the new passive pickups through the active pre-amp EQ on the RGA72? Or if I ditch the active pickups, would the active pre-amp not be usable/not be worth the hassle of wiring up? Looking in the back, there are four wires that go into a little wire socket into the magic pre-amp box. Does anyone have experience with working with this?
It's not a disaster if I have to bypass it entirely tbh, the new pickups will be good enough to sound "right" on their own.
I think I read somewhere that when replacing active EMGs with passives, you have to change the jack? Is this also the case when changing from the Ibanez actives?
I was considering a DiMarzio Pro Track in the neck (through a humbucker-to-single-coil adapter ring) and a Bare Knuckle Nailbomb in the bridge (yeah odd mix and I may have trouble with output and "cut" levels mis-matching...)
Anyone done this and have thoughts/caveats?
Cheers!
Cheers!
