1 - 13 of 13 Posts
Discussion Starter · #4 ·
fettouhi said:
Looks like a RG620 but those had quilted/flamed tops. Is the trem original (installed from Ibanez).
Regards
André
RG620 has a 3-way switch. I don´t know about the bridge.
IMHO, that body has large PU cavities, like those with PU rings.
So, it's a modded one.
Maybe a new wood veener/top and refin? Who knows?
Those PU cavities are large because the PUs were originally most probably V7 & V8 and those PUs require large cavities. The PUs are also direct mounted. I don´t think it´s a modded one.
Discussion Starter · #6 ·
fettouhi said:
Do you know the serial number? Is it AANJ?
Regards
André
I don´tknow the serial, but the seller says it´s from 1996 so I guess the serial is F96xxxxx. Yes, it´s AANJ.
You can´t really see the serial: http://apollo.piramk.fi/~b0301801/ibanez/PICT0014.JPG
Notice that the neck does´t have that skunk stripe in the middle.
It's an RG547AH RBR :).
It's in the '96 Ibanez catalogue which says it's got an Ash Body, Wizard II maple neck,Jumbo Frets,original Edge trem and the pickups are two IBZ V6F's and an IBZ RTS single-coil.
They also did this model in a natural Ash finish.
Very nice guitar;).
EDIT: Oops! Didn't notice the lack of a middle pickup! Apart from that it's identical to the 547.
The only way to be sure is to remove the neck and it'll say what model it is in the neck-pocket.
Discussion Starter · #9 ·
Very nice guitar;).
Yeah, I noticed that guitar too, but indeed, there isn´t any middle pick up on this one.
1 - 13 of 13 Posts
