1 - 15 of 15 Posts
Hi all pls tell me the difference between my RG2550 neck and JEM Necks.
The neck on my old rg450 from 92' is away thin than the Wizard neck on the
new guitar rg2550....
But they say that the rg2550 neck is the most thin neck from Ibanez...
Thank you very much!
The 2005 RG wizard and the 2005 Jem necks (5 piece Wizard II Japan sized) are identical.
They only say the 2550 is the thinest Ibanez neck for 2005 - before 2004 the Wizard was thiner and the Jem 7V neck was chunkier and now (probably reducing cost of production) the RG line and the Jem line have the same neck.
ilia
Discussion Starter · #9 ·
ilia
Hi Ilia! again you are the man of knowledge:)
Thank you for everything!
thank you again more than I can say...
Mitko
p.s
edni priqteli mi naprawiah neocenim podaryk Combo Legacy i tozi Ibanez
RG2550 koito snoshti nosih na lutier da mi napravi setup na necka....
Nadqvam se che si dobre.
S uvajenie
Dimitar
RG 2550:
Width at Nut 43
Width at Last Fret 58mm
Thickness at 1st 18mm
Thickness at 12th 20mm
Radius 430mmR
JEM:
Width at Nut 43mm
Width at Last Fret 56mm
Thickness at 1st 19mm
Thickness at 12th 21mm
Radius 430mmR
Its on the official website but not the US version
Again - that depends on the year of production and the Jem model.
Look here but keep in mind that 7BSB and 7DBK had wizard necs and that for 2005 both the Jem and the RG lines have a 18mm/20mm necks that are absolutely identical even though they are called wizard neck and jem neck repectively.
ilia
ilia
Hi, that not completly true the DBK seems to have a Wizard Neck but the BSB has not..it has a Jem Neck
I have 3 ibanez guitars, one old RG550 (original joint Neck-- is 87 or 88, not sure -- even the Volume know is closer to the Pick up..I already moved it..)..With the wizard Neck 17 mm (1) a 19,5 mm (12 )..i mesured it..
one 98 Rg570 with 18,5 (1) and 20,5 (12) ..i mesured too! ..It suppose to be a wizard too..so i don´t know how consistence are the ibanez wizard necks ..
and one Jem BSB (1998) which i haven´t mesure it..but it feels thicker than the RG570...(it supose to be 19 (1° fret) and 21 (12 fret) acording to the Jm neck especificacions).. the one i like most is the RG550 neck..
Cheers,
Vladdrac
1 - 15 of 15 Posts
