1 - 6 of 6 Posts
I just recently played a RG2610 and really liked the neck and like the sound of the TB10 through my current amp. I did not like the feel of the tremolo. While I am waiting for a RG2610 to come available, I would like to start looking for a different tremolo but I'm do not know which ones will work. Will an Edge or Lo Pro work? Will it take modifications in the route of the body?
Thanks!
BTW...what tremolo came with the 2610?
Hi Al,
The 2610 came with an Edge-Pro. AFAIK, you only choices for a replacement are an OFR or a Gotoh FR. The Gotoh is the better choice.
A Lo-Pro or original edge will require body modifications. The Lo-Pro will require less work to be done.
Discussion Starter · #4 ·
Put an Edge III in....LOL. Kind of a reverse from the usual question.
I'm not sure if I follow? Do people usually ask about the Edge Pro retro fitting in other guitars?...I have got to get up to date on the Ibanez stuff. I have been out of it for ten years.
I had posted about a deal gone bad concerning my RG3120 and a friend that was using the 3120 neck and trem on his RG2610 body. I purchased a 2610 to get the neck and trem to swap back for the 3120 parts. The Lo Pro was on his 2610 body but I did not play it or check out the fit before tearing it down. After swapping the parts and completing his guitar, I checked the Lo Pro fit on the remaining 2610 body. It did not fit. I did notice whatever tremolo studs he used on his guitar looked to be a smaller diameter which would make sense because the trem base plate was hitting the body towards the back of the plate.
Guess I need to search the forums to check out the advantages of each tremolo. I may have not given the Edge Pro a fair shot. The travel of the tremolo did not feel very smooth which was probably not the fault of the tremolo but something weird on the springs or studs.
Thanks!
The 2610. came with 2 types of trems depending on year of make.
2610E= Edge Pro.
2610Z= Edge Zero. (later models)
Ive owned both, both trems seem to equal each other out in the pros and cons however with the lo pr you can do a bit of work to fit an OE or Lo pro in as opposed to the EZ.
Great guitars....Traded them due to no neck pickup and......you ever get sick of bad decisions......
1 - 6 of 6 Posts
