I'm not a luthier so I realize things as I go, mostly before I spend money thank god.
I want to replace the neck on my RG350M, I'm about 100% sure it's a 2010 the SN burned into the headstock is I100606 but none of my research was able to find a serial number format to match it.
It seems to be a pattern that the factory (And in one case month of manufacture.) is designated by a letter at the beginning so mine is either Cort, or September and possibly 2010?
But my question is pretty simple.
I know if I don't want to fool around with it too much I can keep to Wizard II necks made in 2010, or Wizard III necks from 2011 - 2018 which seem to mainly come from S-Series guitars.
I can also use Wizard Nitro necks from the same years.
I started looking for necks when I realized I had all the dimensions except the neck pocket, which would seem to be a fairly serious oversight.
Are all AANJ pocket dimensions more or less universal?
Is there a chart somewhere to tell me what I can do, maybe a resource who specializes in these necks?
I'd really like a rosewood fretboard, and if it had something other than dot inlays, that'd be cool with me too.
Thanks.
Thanks.
