Hey all, I have what I believe to be a 1992 RG470...it previously had aftermarket pickups installed, and I'm trying to return it to stock. (Yes, I have my reasons haha.) Sorry if this has been posted, but I did search...it seems there are a lot of posts regarding the RG inline switch, but none that I could find that talk about stock wiring. Anyway, I'm having some trouble getting it to work. I used this diagram from the Ibanez site:
Problem is that Ibanez doesn't list diagrams that go back to 1992, and I think these guitars changed in 1994 when production moved to Korea. This one is for a 1994, and it doesn't seem to work right at all with my guitar. I also noticed that, being a '92, my guitar doesn't have the same pickups listed in the diagram. Anyone have a diagram for a '92-'93 RG470? I'm pretty sure this guitar is a 470 but not positive. It's made in Japan, jewel blue, has a rosewood fingerboard with dot inlays, edge trem, and V7 / S1 / V8 pickups. But no pickguard and no tilt heel.
As it is, the neck position clearly sounds like the bridge pickup, and the bridge position doesn't work at all. Likewise, the bridge / middle position is just the middle single coil. The middle position works fine, and so does the neck / middle. And before you ask, no, I don't have the switch backwards
There is very clearly one pole that has never been soldered to, and it's the fourth from the right, just like that diagram. The ground on the second pole from the right looks factory as well.
I've checked and double checked all my connections, and everything looks fine. All pickups are well grounded. Clearly something with the switch is not wired correctly. These inline 5-ways confuse the hell out of me...I'm just about ready to ditch it and install a standard 5-way, or maybe even one of those super switches.
Thanks in advance for any help. I'd really like to get this thing up and running again.
