So I’ve been wanting to change out some parts on my 2019 RG470 and I could use some advice for any retrofitting or replacing components.
Oh, i posted it ages ago lolThat wiring diagram would be greatly appreciated right now... I believe that since my guitar was a customer return, somebody during the process changed the wiring and it's all the wrong colors for a normal Ibanez.
No dude... This is only done for 3 way switches; where theres no push pull pots (basically no ibanez models, I genuinely cant think of a single one). On 5 way switches (basically every ibanez model); on H/H guitars the neck is wired for series in pos 5, and parallel in pos 4; then both pickups with split coils in pos 3, then split coil alone for bridge pos 2, and then pos 1 is full humbucker. In H/S/H the neck and bridge pickups are split and combined with the single mid in pos 2 and 4. H/S/S is basically identical to H/S/H. If you're taping up the white and black wires, you get zero options of splitting or parallel wiring.DiMarzio provide wiring diagrams with their pickups, as well as their website. All that information is widely available with a simple search online.
In short, Red wire goes to the pickup selector where the old pickups wire was, join and tape off the black and white ones, green and bare to ground (probably the back of the pot).
Yeah, sorry I forgot, the white and black joined go to the other spot on the switch. But again, as I mentioned, the OP can find this stuff easily on the DiMarzio website anyway.No dude... This is only done for 3 way switches; where theres no push pull pots (basically no ibanez models, I genuinely cant think of a single one). On 5 way switches (basically every ibanez model); on H/H guitars the neck is wired for series in pos 5, and parallel in pos 4; then both pickups with split coils in pos 3, then split coil alone for bridge pos 2, and then pos 1 is full humbucker. In H/S/H the neck and bridge pickups are split and combined with the single mid in pos 2 and 4. H/S/S is basically identical to H/S/H. If you're taping up the white and black wires, you get zero options of splitting or parallel wiring.
"All that information" is largely meaningless if youre not even sure what youre looking at to start with.
