I have a older rg550 I am refinishing. I have noticed that one of the studs has an ever so slight play to it. A guitar tech I talked to said to pull the whole thing out and add some white glue or wood glue(which he said would be better as it will fill in the gaps and stop the play w/o adhereing to the metal) paying careful attention not to add too much covering the set screw??? Is this what I should do? or is there a better way of doing it? Is there any newer studs on the market that would be better. Any advice would be greatly appreciated, I would hate to make things worse!! Should I just leave it as is?? thanks so much, Tim..................
