1 - 6 of 6 Posts
Is it possible.to mount an rg550 pickguard on a rg570 body or do I need to modify the pickguard for it to fit?
The pick guards will fit fine, but as mentioned, the 5-way slot is the wild card. A 550 guard will have the narrow slot and might interfere with the #1 and #5 position because of the thickness added by the guard. I use a router table with a 1/4" bit and made a sled that the pick guard screws onto to open the slot(go from 1 screw hole to the other and its perfect). If you're okay with a clear guard, then a Jem FP would already have the slot cut. I've done this mode to several RG and Prestige guitars over the years.
https://hosting.photobucket.com/alb...jpg?width=279&height=169&fit=bounds&crop=fill
1 - 6 of 6 Posts
