i want to tell you a real simple thing i did to my tone zones that made them sound much better
you take off the fabric tape that wraps the two coils and protects the wires
then take out the screws that mount the coils to the baseplate
now carefully remove the metal bar the screw poles pass through
next you want to make the magnet contact the screw poles now that the metal retainer bar is removed.
the creates the "AIR" gap dimarzio uses on the air buckers but only one coil is air bucker on this version of the TZ
what this does is lower the TZ's output by a small margin and it makes the tone zone not so damn thick and boosted all then time,it is a lot more vocal and open this way now
this version sounds much closer to the custom wound bridge pup eddie used in the EBMM sig guitars
it is a kinder, gentler TZ but still mean as a pissed off lion when you want it to be!
hotter than the air zone and more aggresive still but less than a stock TZ
real cool simple mod that i turned many EVH fans onto
