Some help with a Jem 555! Thanks in advance!!
1002 Views 8 Replies 5 Participants Last post by  Cobra
Hey fellas ,
Well , im building a Jem 555 with a body i bought , I was thinking to drop a Edge or an edge pro in there .. and i was wondering if thats possible , since i have NO knowladge about guitar tech besides changing strings pretty much.
Im afraid i dont wana mess it up , or anything!
The edge pro is too expensive for my pocket , so im gona go for a single edge . Another thing , i need to buy some dimarzio pickups , it will be cool if you guys drop me some info about the Evo pickups , and would it be bad if i go an Evo on the neck and a EMG 81 on bridge???
Well any info will be really apreciated!! Thanks in advance!! I ve been reading a lot of stuff the past few days , this community kicks butt!!
1 - 9 of 9 Posts
If it is a 555 body you will have to do some route job to fit the edge in ....
Ced
The EMG 81 is an active, low impedance pickup, the EVO is a passive, high impedance pickup - there are some complications (for example, from memory the EMG pots are 25K, whereas the standard Ibanez ones will be 250 or 500K) - I suspect they have to have a totally separate signal path until you hit the output socket - anyone else out there confirm this?
Good Luck with the guitar
David
Wow , thanks guys for the info... a route to fit in the edge?? dang i think im gona stick witht he TRS II Stock! ...
I own a 350Dx right now , with that trem , and i dont see a problem with it.. maybe becouse i havent tryed an edge??
Cobra said:
...and i dont see a problem with it.. maybe becouse i havent tryed an edge??
yes :D
You can stick an Official Floyd Rose in there.
There is a small chance for a direct fit with an edge but OFR is the safer option.
Regards
André
Edit: Andre just answered my question.
Can i install it myself?? or i need any pro to do it for me??
Im gona research about those bridges when i get home , thanks fellas!! :)
btw are those OFR good as an edge??? Thanks again!
1 - 9 of 9 Posts
