1 - 2 of 2 Posts
Hello everyone, I hope one of you can give me some insight into my problem here.
I just reinstalled Sonar 8.5 producer edition. I have never run into this issue before.
When I record a track it is sped up when I play it back. It doesn't gradually get faster, it is around 1.5 times faster from the beginning to the end.
I know it's not my sound card, which is an Maudio Delta 1010LT because I can record in Audacity and everything works fine.
I have installed Sonar 8.5 several times and never ran into this issue.
Any Ideas? Any input would be helpful, Thank You.
Interesting...I’ll take a stab at it:
Weird things like this can happen if the sample rate within the DAW session is different than the sample rate of your audio interface. I would start by making sure the sample rate Sonar is using to record audio matches the sample rate your audio interface is using.
1 - 2 of 2 Posts
