that's what I would do, I can't see why it wouldn't work.I guess the machined tip going into the female block keeps things in proper alignment.
My only idea then is to get longer bolts, grind them down on the bench grinder, & use a tap & dye kit to fix the end threads.
I would pull one of the screws out, head to your local hardware store and find a nut that fits. Get a tap and die of the nut thred size and you're good to go.Hi Rich, can you tell me the dimentions of the bolts cuz I have no way of measuring
them. I'm planning to buy a tap & die set so I can "hand machine" my own bolts.
Thanks!
Mike
p.s. there was no info on Ibanez.com![]()
oh yeah, more than likely it's metric.Hi Rich, can you tell me the dimentions of the bolts cuz I have no way of measuring
Thanks!
Mike
They're just M4's.
