7's
7-STRING GUITAR
STANDARD TUNING, 25.5" SCALE
________________________
Gauge: 9-54 Standard Set
Scale: 25.5"
Tuning: Standard
*NOTE: The standard D'Addario 7-string set, EXL120-7. The low-B string tension is, frankly, absurd. It is barely higher in tension than the high-E string! So who comes up with these gauges... a monkey? :lol: The tension on the thickest string here is very low. This is exactly what you don't need on your 7-string guitar. It can only lead to flabby tone, sloppy, unbalanced feel, bad breath and low sex appeal.
Gauge: 9-59 Custom Set
Scale: 25.5"
Tuning: Standard
*NOTE: Aaaah, that's better. This is the corrected 9's set, and what D'Addario and any self-respecting string manufacturers should be offering, in my opinion. The improvement in tone and feel is obvious if you've spent any time with the standard set. The extra three pounds on the low-B string make a good difference here.
Gauge: 10-59 Standard Set
Scale: 25.5"
Tuning: Standard
*NOTE: The standard D'Addario 7-string set, EXL110-7.
Gauge: 9.5-66 Custom Set
Scale: 25.5"
Tuning: Standard
*Note: As an alternative to the standard 10's set, this could be a good one. It replaces the high E string with a 9.5, so it's slightly lighter and easier on bends, but there's still plenty of tension. For a heavier alternative, see below.
Gauge: 10-68 Custom Set
Scale: 25.5"
Tuning: Standard
*Note: A heavier alternative to the standard 10's set.
STANDARD TUNING, 27" SCALE
Scale: 27"
Tuning: Standard
*Note: This should work well for a 27" scale 7-string.
7-STRING GUITAR
Scale: 25.5"
Tuning: Standard
Code:
E: .009" [PL] = 13.13 pounds
B: .011" [PL] = 11.01 pounds
G: .016" [PL] = 14.68 pounds
D: .024" [NW] = 15.77 pounds
A: .032" [NW] = 15.77 pounds
E: .042" [NW] = 14.77 pounds
B: .054" [NW] = 13.57 pounds
Total Tension = 98.70 pounds
Scale: 25.5"
Tuning: Standard
Code:
B: .012" [PL] = 13.11 pounds
E: .044" [NW] = 16.10 pounds
B: .059 [NW] = 16.48 pounds
Total Tension = 105.04 pounds
Scale: 25.5"
Tuning: Standard
Code:
E: .010" [PL] = 16.21 pounds
B: .013" [PL] = 15.38 pounds
G: .017" [PL] = 16.57 pounds
D: .026" [NW] = 18.41 pounds
A: .036" [NW] = 19.54 pounds
E: .046" [NW] = 17.48 pounds
B: .059" [NW] = 16.48 pounds
Total Tension = 120.08 pounds
Scale: 25.5"
Tuning: Standard
Code:
E: .009.5" [PL] = 14.63 pounds
E: .050" [NW] = 20.46 pounds
B: .066" [NW] = 20.51 pounds
Total Tension = 125.5 pounds
Scale: 25.5"
Tuning: Standard
Code:
B: .014" [PL] = 17.84 pounds
G: .018" [PL] = 18.58 pounds
B: .068" [NW] = 21.73 pounds
Total Tension = 132.76 pounds
Scale: 27"
Tuning: Standard
Code:
E: .009" [PL] = 14.72 pounds
B: .012" [PL] = 14.69 pounds
G: .016" [PL] = 16.46 pounds
D: .024" [NW] = 17.68 pounds
A: .032" [NW] = 17.68 pounds
E: .044" [NW] = 18.05 pounds
B: .059 [NW] = 18.48 pounds
Total Tension = 117.76 pounds
