1 - 4 of 4 Posts
Hi, I just go a RG3550MZ and I want to adjust the action. I wanted to "unlcok" the lock bolts in studs, but they are not there. However if I want to adjust the action with the actual studs, they won't move at all :cry:.... any advice for this?
I think they are probably there. The allen key is very fine that fits into that locking stud. Make sure you are using the right one!
It's not stuck if you can raise it, and if you're trying to lower it they're just locked. Always raise first to unlock.
Discussion Starter · #4 ·
Thanks for the replies. My father solved it today, I was just too worried to put some strength into it (the locking bolts aren't there) and everything works well now.
1 - 4 of 4 Posts
