Anyone on here managed to fit a Sustainiac in an RG550 Genesis, without resorting to routing out the control cavity?
Just reading the installation manual for the Sustainiac and it states that the more recent Jems now come equipped with a wider 5 way switch, which prevents the installation of the circuit board without routing out the cavity a little. I wonder if the RG uses the same route?
................."NOTE: Newer Jem guitars use a new VLX-91 switch that is wider than the old VLX91. This new wider VLX 91 takes up so much room inside the tiny Jem cavity that the Sustainiac circuit board will not fit into the cavity. Therefore, we have to create a new cavity under the pickguard for the Sustainiac board."
