1 - 8 of 8 Posts
My new combo amp has a Celestion 70 watt 8 ohm speaker. I'm thinking of switching to a Celestion Vintage 30. I found a sweet deal on a Vintage 30 that's 16 ohms.
Question: My amp has a dial to switch to 4, 8, or 16 ohms. If I install this 16 ohm speaker and switch the dial to 16 ohms I should be set?
Also, should I really be looking for an 8 ohm Vintage 30 or will the 16 ohm speaker be ok. Any forseeable issues with switching?
Thanks
Just set the impedance switch to 16 ohms and you'll be set. If you decide to use an extension cabinet later, get a 16 ohm cabinet and set the selector to 8 ohms if you are using the cabinet and the internal speaker together.
Roger
1 - 8 of 8 Posts
