1 - 5 of 5 Posts
Discussion Starter · #3 ·
Looking to replace my Talman tuners. Where can I get compatible 3+3 staggered tuners from? Also, it looks the posts have 5 different heights (not 3 as I expected).
The Prestige models use Gotoh SG360 MG-T Showbox jiofi.local.html tplinklogin , while MICs seems to use Musiclily: Value Musiclily 3 Per Side Set of Guitar Locking Machine Head,Chrome | Musiclily.com[/url]
However, none can be ordered in staggered 3+3 configuration.
am looking for fixing the isuue i have the same problem ? any updates ?
Discussion Starter · #5 ·
I ended up getting a custom set of tuners from japarts (~$75 shipped from Japan). You need the following specs:
Gotoh SG360-07-C MG-T L3+R3
Body: SG360 14:1 Flush
Headstock: 3 left (bass), 3 right
String Post: Magnum Lock - Trad
(thumbscrew)
String 1,6: Ex-Long (21.5mm)
String 2,5: Long (20mm)
String 3,4: Short (18.5mm)
Finish: Chrome
Button: 07 Modern Mini (metal)
Not a drop-in replacement (you need to drill new holes for the screws), but install was quite easy.
1 - 5 of 5 Posts
