The evolution pickups. I realized I don't like them
11K views 25 replies 11 participants last post by  iusedtocutthegrass
My thoughts:
Really bad pickups (eg like the Chinese squier strat I started on) need a swap. As they often have mushy ill defined output.
Once you reach a certain quality level, before I worry about swapping pickups make sure you have these two steps covered:
1. A good quality amp (or plugin modeling thingy). Because that's the foundation.
2. An EQ pedal. Use this to adjust for the tones you want. E.g. I really like my Paf Pro loaded Jem/Pgm but I think the midrange bump on my JS is too pronounced. Much cheaper and easier to just reduce it slightly with the EQ pedal than to change the pickups.
(EQ as a boost is also my favorite way to reduce the volume gap between the single and humbuckers in an HSH setup)
