tremolo arm on edge pro´s
1360 Views 8 Replies 5 Participants Last post by  canneerr
(i´m sorry for repeating this text again, but it was in another post, that no one replied... :( )
hi, i´m new here, english is not my mother language, so excuse me if i´ll do some kind of "language-mistake"!
i always take out the tremolo arm when i´m not playing, ´cause some days ago i left it for 2 days in the case, and i noticed that the bridge was a little "pushed-down", because the arm touch the case... (i hope it didn´t made anything bad to the springs, i think not).
anyway, because the arm is always getting in and out in the bridge, the washers may suffer a little, so it´s not too stiff as it was a month ago (the guitar is new). i also noticed that there is a ind of a "gap", it´s a question of not even a milimeter, but the arm is not 1000000% stick to the bridge (i hope you get my idea, it´s like you "feel" the arm with a very very little space inside the hole, that lets it 0,000001 milimeter gap) . is it normal due to the use?
thank you!
1 - 9 of 9 Posts
You could probably fix it with nail polish, http://www.jemsite.com/tech/3other.htm#tremarmrot
The mod is to make the bar spin less freely, but it would probably take out any extra play in the bar too..
yes i´ve been thinking on that, but in a month, i thought the washers should keep in perfect conditions for longer time...
Not so sure about that. I go through those plastic washers continusly! When I go to the music store, I always pick up how ever many they have. If you use your trem a lot, your just going to have to face the fact you'll be replacing the washers quite frequently....In fact - I am replacing mine again tonight before we practice;)
Washers don't long
I've found a useful solution is cutting a small round piece (~15mm diameter) of plastic bag - like the bag daddario strings come in,
Place the plastic over the hole and push the bar in - this works and lasts for ages
markg5150 said:
Washers don't long
Interesting idea....I may have to try that one;)
How long do the washers keep the tremolo bar in condition?(i want the trem bar not to fall down when i don't hold it in my hand,i want the trem bar to stay in one point,how long does it take with new washers?)
Entirely depends upon how much you use your trem. I use my trem a lot and so I have to replace them a lot. Pretty easy to tell when you need to replace them. It's really personal preference. I never let mine get to the point where the trem just drops. To me that's too far gone.
how many days does it take to change them with new ones?I use 3 hours in a day,use trem very often,and don't want it to drop,and i just wonder how many days does it take...
1 - 9 of 9 Posts
