1 - 5 of 5 Posts
· Registered
Hi guys, just wondering if there's anything wrong with using both gauges of spring that come with Edge zero ii equipped guitars? My RGD has a 7 string edge zero ii tremolo and I'm tuned to e flat (7th is b flat) so... B flat standard I guess? Using 09-46 with a 54 on the bottom. It seems like there's not enough tension when using the stock springs, and slightly too much when using the power springs. I don't really want to change string gauges, so could I use 1 power spring and 1 regular spring? Theoretically, that would completely solve my problem. I'm fairly experienced with trem systems, and I feel the only options I have are to use uneven spring gauges or change string gauge. Thanks in advance.
· Registered
Hmm, I have an Edge Zero 7 with standard springs and tuned flat like you with 9-46 and a 56-string.
Works perfectly for me. The tension knob is pretty much centered.
OTOH I don't see a problem with mixing springs. Give it a try.
1 - 5 of 5 Posts
