1 - 4 of 4 Posts
Hi
I just bought a new Whammy DT.
The Whammy side works well, but there is a problem with the Drop tune side.
When i play a note i hear the original note AND the Droped note through the amp.
It´s get worse the thinner the string is, it´s ok on E and A strings, but this is unusablee. If I play really soft it is less noticeble. Sounds just out of tune, with the original along with the droped signal.
Anyone know this pedal?
Not the most reliable pedal in the world. After a year or so of mild usage, I had a switch go, about 5 of the LEDs started burning out.
Pretty lousy if you ask me. If you registered it, I believe they had a 5 year warranty.
I've had mine for a month or so. I use it heavily and very hard. I'll be more gentle with it and I hope mine will last longer...
I did get the guitar center 2 year Garuntee warrantee if there's a problem (including accidents) so if it dies within two years I get a new one...
Mine has worked flawlessly for almost 4 years. I got mine when they first came out. The drop tune side is what I use the most, and I use it a lot. No problems whatsoever. Hopefully they honor the warranty. If mine ever does go bad, I'll get another as the drop tune side is very handy.
1 - 4 of 4 Posts
