1 - 9 of 9 Posts
there's three ways to strip finishes..
1. Heat
2. Chemicals
3. Sanding
Heat doesn't always do the trick and it requires a heat gun
Chemicals work but they leave a caustic coating on your guitar that needs to be sanded off and washed clean before refinishing
Sanding takes more time but is the safest and simplest method.
then fill it in with wood filler and re-sand it. If you are taking the finish off then it's not a big deal cuz you might have to fix dents or holes already. Just don't sand through when you are sanding the new color or clear coats.
I would think it would depend on if you have a Male Finnish or female Finnish.
The Finnish are a decent people with much oft he same wants, needs and desires as you and I, being sensitive to their needs would provide you, and them, with many hours of enjoyment.
Always be safe.
Bamm
Always be safe.
Bamm
LMAO That was good...XD
1 - 9 of 9 Posts
