1 - 20 of 25 Posts
What would your specs be?
Neck, pickups, wood, color, headstock, Trem(or hard tail), etc?
This should be fun topic :grin:
(I honestly don't know what I would choose)
Mine would be exactly the original Prestige 3120 with just a skad thicker neck. I'd like it available in white or red with black or mirror pickguard with matching headstock. Perhaps a ebony fretboard.
One piece jem alder body monkey grip lion claw etc, one piece jem birds eye maple neck with ebony or brazillian rosewood fretboard with last 4 frets scallop, square heel joint with jem plate,lo pro bridge or edge,pink pups of paf pro or breed dimarzio,original floral design or multi color, mother of pearl vine inlay with leaves.... And all that for price tag $2000 hahahaah
Mahogany stained oil S series. 24 fret ebony fretboard 24 3/4 to 24" scale. Orginial Wizard specs Two humbuckers, one volume control, and a toggle switch. The knife edge Z or ZR trem (Both are great) Three tuners on each side of the headstock.
A couple of things would be cool. I like pretty much what is on the Timmons guitar but maybe more the traditional single coils instead of ss space rails. A Scofield type AS200 guitar would be nice, too. As for pickups the Timmons type has DiMarzios and there's nothing wrong with that and AT at bridge, and Class of 55s at middle and neck positions. A Scofield type with simple Seymour Duncan JB and 59 pair would be excellent.
RG-565
Mahogany body w/ 1/2" sick quilted maple top.
Edge Lo-Pro
Direct mount pickups
Tone Zone & S1 Pickups (love the sound you get from the S1 when wired backwards)
3 Way switch (bridge side coil & S1 for middle position)
Viper profile AANJ neck w/ the tightest grained maple board in life
2 abalone off set dots @ the 12th
Matching reverse headstock.
Angled jack - volume only - JPM switch
Colors:
Pink stain w/ black hardware
Purple stain w/gold hardware
Nude w/gold hardware
Then let the 2 year world tour begin
simple-
RG3125- quilt top, ebony board, with a deep ocean blue burst.
RGT3125- quilt top, maple board, emerald green burst
Spalted Flame Maple RG Body
Buckeye Burl Top with bevels
5 Piece Rosewood Neck with Ebony Fillets, Original Wizard Profile, Reverse Headstock
Pale Moon Ebony Fretboard
Lo Pro Edge Trem
Direct Mount H/H BKP Nailbomb and Aftermath pickups
Ibanez AR100F
Neck: Maple/Ebony 5 piece neck w/KTS titanium rod (neck thru)
Body: Flamed Maple top/Mahogany body (RGA)
Fretboard: Ebony fretboard w/blue wedge sharktooth inlay
Bridge: Edge-zero bridge/ZPS3
Hardware color: Cosmo black
Finish: Transparent Blue Burst (High Gloss)
Neck dimensions:
Scale: 25.5"
Width at Nut: 43mm
Width at Last Fret: 58mm
Thickness at 1st: 17mm
Thickness at 12th: 19mm
Fretboard radius: 430mm
Frets: 24/Jumbo
Electronics:
Neck pickup: Seymour Duncan Black Winter (Black)
Bridge pickup: Seymour Duncan Black Winter (Black)
Pickup Configuration: HH
Controls: Seymour Duncan Liberator Volume Potentiometer, 3-Way Pickup Switch, Kill Switch
ETC:
Strings: D’Addairo EPS510 ProSteels, 10-46
Tuning: Drop C
7 string
Body: Arch top (jazz box) style RG body shape. (Conklin made something that looks similar but I can't find the picture anymore.) Spruce top, Indian Rosewood back and sides. The body would be hollow enough to have the acoustic properties of an arch top but still be able to handle high gain tones. (ala PRS Hollowbody)
Bridge: The bridge would consist of individual saddles (ala Standberg) but locking, locking tuners.
Neck: 24 fret Wizard neck (maybe a tad bit thicker) with EBMM style truss rod, jumbo stainless steel frets, ebony fretboard
Pickups: Not sure to be honest
Case: Every guitar would come with an Accord Flightcase!
I'd have a tweaked up version of my #1, which is this:
Alder body, ebony board, SD pups. Modified switching so the blade lever goes bridge, neck/bridge, neck, neck/middle, middle.
Tweaks would be rear routed, non-locking whammy, slightly modified forearm cut, no binding, no dots on the front of the neck, non-angled single coils.
Then, maybe another variant with a thicker old Roadstar style neck.
Super Moderator
I'd have the RG550 as my signature model with a large percentage cut of each one ever sold :D
Or failing that, an RG770DX style guitar, so the square neck heel and a clear pickguard, in black with gold hardware including an original edge bridge. Abalone purfling like the JEM10 and the split block inlays more commonly seen on the old Artist models in an ebony board.
I'd have to do some A/B testing to determine the body wood and pickups.
Reversed headstock 25.5" scale RG7, blood red finish, white Blaze pickups (HH), tortoise shell pickguard, no inlays, ebony fretboard, maple neck, hipshot bridge (chrome), two volume knobs, three way pickup selector.
a regular 6 string 25.5 inch scale RG, but...
5 Piece Ash-maple-walnut-maple-walnut-maple-ash body to ad some crispy range
a 5pc Super Wizard HP Maple/Walnut neck w/KTS™ TITANIUM rods(taken from the page :p)
Ebony fretboard, with offset dot abalone inlays and SS 6105 frets
Ibanez LO-PRO Edge with a tremol no included(to quick adjustments)
And Tilt Neck Joint.
In Ibanez kind of table:
Neck:5pc Super Wizard HP Maple/Walnut neck w/KTS™ TITANIUM rods
Body: 5 Piece Ash-maple-walnut-maple-walnut-maple-ash body
Construction: Tilt-Neck Joint
Fretboard: Ebony fretboard Offset Abalone Dots(20-24 Scalloped)
Bridge: Lo-Pro Edge bridge W/Tremol-No System
Hardware color: Black
Finish: Violet Chameleon
Fret SS/6105 frets w/Prestige fret edge treatment
Neck dimensions:
Scale 648mm/25.5"
Width @ 0F 43.0mm
Width @ 24F 58.0mm
Thickness @ 1F 17.0mm
Thickness @12F 19.0mm
Radius 430mmR
Electronics:
Neck pickup: Dimarzio Air Norton
Middle pickup: Dimarzio True Velvet
Bridge pickup: Dimarzio Evo2
Pickup Configuration: H-S-H
Controls: 5 way blade, 1 Volume, 1 Tone W/push-push system
Others: Ultralite Tremolo Arm, Schaller Key Holder(back of the headstock)
Strings: D'Addario EXL116 Nickel Wound, Medium Top/Heavy Bottom, 11-52
Factory Tunning: D-G-C-F-A-D
7 string
Pre 2000 UV neck with reverse headstock, ebony fingerboard, Jumbo frets (The neck may be build of several parts, but must have the orig. Pre 2000 UV neck specs)
Rear routed UV body
Blaze II pickups
Lo-Pro Edge
A kill switch
5-way selector with some small mods in a custom position as compared to the orig UV
Only one Volume pot, no tone pot in a custom position as compared to the orig UV
A standard spring loaded damper arm which clamps onto the side of the headstock.
Colors:
A satin white one with DP in white
A non-gloss black one with MCDP
A donny-style one with custom Memes pattern and meme inlays.
(however, what I REALLY want is a Zoot 9-string :mrgreen:)
Regards,
JP
1 - 20 of 25 Posts
