1 - 4 of 4 Posts
Discussion Starter #1
I found this Ibanez at my local online-store, and I am trying to find it's model, but I can't. Can u help me?
16915
16916
I'm no expert on older models, but the construction looks rather odd (i.e. I think it's a fake).
Front-mounted jack socket at 90 degrees to the body! :oops:
Neck-thru but with a prominent 'bump' where you would expect a smooth transition into the body (or a neck joint if it were bolt-on / set-neck).
5-piece neck without a central maple stripe.
Head-stock appears to be straight, rather than slightly angled (as is typical), and lacks a volute.
Shape of the head-stock (although perhaps it's the camera angle).
Positioning of the hardware (pups, bridge & pots).
Bridge routing looks like a DIY job that was either poorly measured up or originally done for a different bridge.
Locking nut with thumb screws instead of hex screws.
Also, it's more than slightly random to have one pickup adjustment screw on the left and two on the right (how would that even function?). See the RHS of each mounting plate - two screws for the neck pup and two empty screw holes for the bridge pup (with a screw between them).
In short - do not buy this!
1 - 4 of 4 Posts
