1 - 10 of 10 Posts
I'm getting the neon yellow rg550 w/a yellow bridge pickup and pink knobs for $250? What year did they make the 550 in neon yellow? Also where can I get a replacement neck plate? The one on the guitar use to black and is now half chrome.
(Edited by Noodles at 12:31 am on Dec. 24, 2000)
Will it fit?
I believe that the 550 came in DY in 87-89. It was later reissued back in 1999.
You can get a new authentic Ibanez neck plate from your local Ibanez dealer, although it would probably make more sense to just buy an All Parts (or some other part supplier) neck plate from your local guitar store.
You can also try to remove the remaining finish from the neck plate, and refinish it yourself using "Rustoleum" spray paints, which are durable, and designed to endure "abuse."
Discussion Starter · #4 ·
Will it fit?
Can anyone tell me if the warmoth neck will fit because it says on their site that they are made to fit strats?
Will it fit?
As long as the Warmoth neck is 25.5" scale, it should fit fine. You will need to let them know it's for an Ibanez.
Ibanez 24 fret necks are basicaly 22 fret necks with extensions for the 23rd and 24th frets. Warmoth doesn't use this extension, but will be able to accomodate you on a special order. Don't look for the headstock to be even close to the Ibanez design. However, I've read on the sit that they can do the profile.
J>
Discussion Starter · #6 ·
Will it fit?
Thanks for the help Jimm. I checked out their 25.5 necks and I think I'm just gonna start to save up for my first jem(either a 7pbk or a 777vbk) after I get this guitar. Thanks again though.
Discussion Starter · #7 ·
Will it fit?
I got the guitar and I have a few questions. First It has a DiMarzio pickup in the bridge and in the middle and neck are two none stock pickups with no markings. Can anyone tell me what the DiMarzio is? It says DiMarzio, made in U.S.A. and DP-152. Also the strap buttons have been removed and replaced with leather pieces that hold the strap on and I was wondering if anyone could tell me what they are so I can get them for my 7620. Thats about all for now I'm still inspecting the guitar. Thanks for any help given.
Discussion Starter · #8 ·
Will it fit?
I have one more question, where can I get direct replacement gotoh tuners? The ones I have seen would require drilling of a new screw hole.
Will it fit?
The DP-152 is not in the 2000 cataloge. I believe it is a Super II, but I really don't know. Email DiMarzio, they will answer that question for you.
J>
Discussion Starter · #10 ·
Will it fit?
I e-mailed them this morning and they said it was a super3. I love the distorted sound.
1 - 10 of 10 Posts
