Depends on the neck config but more or less YES!lyconxero said:So then it's possible to swap like a Wizard Prestige neck for a Wizard II neck? I only ask because I really want a good fixed bridge RG but don't have $1000 or $1500 to shell out for one of the Prestige RGA's. I'd love to just buy like an RG321 and swap the neck with a Prestige neck that someone has for sale if it can be done as simply as unscrewing one and putting on the other.
I like Wizard IIs also. They're much closer to the JEM profile than the Wizard is. My hands are quite big and the Wizard makes them cramp up.jra2217 said:i can't belive you would want a wizard 2 in place of the original!!!!!!!
i think it would work, if they were both non aanj bolt on and had the same number of frets so iwouldn't mess up the scale or if the neck would hang over into the neck pickup.
