1 - 3 of 3 Posts
Hey guys,
Anyone play through this effects unit? I have one and would like your input on getting a good lead delay effect, among others if you're willing to share :)
Thanks!
Yeah....tweak channel 76 or 79....echoplex....I usually use that one only....haha
Key is switch under the mixer setting to analog instead of digital...cancels the hush, but that thing sucks anyway.
^^ +100
Using the mixer section is the key to using the Xpression effectively, but most people overlook it. You can also use the mixer as a boost for your solos, so when you kick in the effects loop with the delay, you can boost the signal as well. Just set both L and R outputs to anywhere from +2 db to +6 db depending on how much boost you want.
Cheers,
Race
1 - 3 of 3 Posts
