M150C Top falls 180 degrees - Jemsite
post #1 of 5 (permalink) Old 04-28-2012, 05:58 AM Thread Starter
Anybody know how to fix the 2 inner straps that are supposed to hold one section of the hardshell case 90 degrees when you open it? The straps are still there but it rotates 180 degrees causing the top part to fall to the floor.
Thanks!
axeman1 is offline
post #2 of 5 (permalink) Old 04-28-2012, 01:49 PM
Re: M150C Top falls 180 degrees
It needs to be reglued in the correct spot.
Rich is offline
post #3 of 5 (permalink) Old 04-28-2012, 10:06 PM Thread Starter
Thanks Rich. Is there an accurate way to determine the "correct" spot? I'm trying to simulate where it should go by holding it in different areas and where it would look fundamentally sound the most. I'm worried I'll glue to the wrong spot and I'll have to tear it off again and cause damage to the strap and the attaching area. Lastly what glue should I use? I'm thinking a glue gun might work.
Steve
axeman1 is offline
post #4 of 5 (permalink) Old 04-28-2012, 10:16 PM
Glue gun. Slightly past verticle so it stays open.
Rich is offline
post #5 of 5 (permalink) Old 04-28-2012, 10:26 PM Thread Starter
Great. I'm ready to give it a go. Thanks
axeman1 is offline
hardshell case , m100c , m150c
FS: Ibanez USA Custom Hardshell Case M150C Jimbo72 Classified Ads: Guitars and Gear 0 02-06-2012 10:31 PM
WTB M150C Case for my JS600 satchhead Classified Ads: Guitars and Gear 0 01-03-2011 10:25 PM
IT'S 42 DEGREES C (107 fahrenheit) crevis Off-topic / Miscellaneous 55 10-29-2007 11:34 PM
does anyone else hope the VH reunion falls apart!? Ki swordsman Off-topic / Miscellaneous 36 10-09-2007 05:52 PM
help with truss rod: trying to loosen, but the nut FALLS OFF ddk Tech: Setup, Repairs and Mods 4 05-07-2004 07:10 PM
