RG7420: Can I swap Lo TRS 7 with a Lo Pro Edge 7 or Edge Pro 7? - Jemsite
post #1 of 10 (permalink) Old 02-12-2013, 09:20 AM Thread Starter
webmaestro's Avatar
Just as the title asks, I have the opportunity to buy a 2000 RG7420 in decent shape. However, I don't want the Lo TRS 7 on there, so I'll only buy it if I can swap it out with a Lo Pro Edge 7 or Edge Pro 7.
Are either of these a direct swap? I'll want to replace the trem studs with locking studs as well (something I do to all my guitars).
Thanks in advance.
webmaestro is offline
post #2 of 10 (permalink) Old 02-12-2013, 09:31 AM
Re: RG7420: Can I swap Lo TRS 7 with a Lo Pro Edge 7 or Edge Pro 7?
to my knowledge NO.
The 6 string lo-trs will not swap with an original edge or a lo-pro. I am 99 percent sure it is the same on the 7 string.
I know you can swap out a lo-trs 6 string with an original floyd rose though.
I think the issue is the clearance for the trem's sustain block and the top route is too shallow for the thicker/deeper edge and lo-pro
j.arledge is offline
post #3 of 10 (permalink) Old 02-12-2013, 10:07 AM Thread Starter
webmaestro's Avatar
So, not the Edge Pro 7 either? I'm open to any of the higher-end Ibby trems. I have Edge Pro 7's on my other guitars.
post #4 of 10 (permalink) Old 02-12-2013, 03:59 PM
Reviews: 120
Why don't you want the LO TRS 7 in there? Is it just because of the term "LO TRS" in the title? The only really crappy version was the LO-TRS II that was used on Korean made six string RGs and the like. The Japanese six string version "LO-TRS", and I believe the LO-TRS 7 were actually decent trems that didnt' wear out prematurely, and were capable of holding tune with a decent setup.
LonePhantom is offline
post #5 of 10 (permalink) Old 02-13-2013, 11:46 AM Thread Starter
webmaestro's Avatar
I hear what you're saying, but I'm a trem snob. I've tried many, including original Floyds and the newest Edge Zero's, and the only ones that feel right to me are the Lo Pro Edge and Edge Pro's (even though I got my start on the original Edge, it was never as comfortable to me as the LPE's and EP's).
This is why I'm a slave to the used Ibby market, can't stand the newer EZ trems.
That said, I've never actually played a Lo TRS, and might love it. Just not sure I want to take that chance and drop a few hundred bucks when I'm not 100% sure.
post #6 of 10 (permalink) Old 02-13-2013, 01:47 PM
Reviews: 120
It's not a big job to retrofit an Edge 7 if you didn't like it anyway. The studs should be in the right place, and the cavity probably wouldn't need much work to fit the trem. You could do it by band with sand paper if you don't have a Dremel.
post #7 of 10 (permalink) Old 02-13-2013, 02:46 PM Thread Starter
webmaestro's Avatar
OH! The trem studs are all I'm concerned about, actually. I don't mind doing some modification to the trem cavity at all. If the studs are in the correct spot to accept a LPE7 or EP7, I just may have a new (old) guitar soon.
post #8 of 10 (permalink) Old 02-13-2013, 04:55 PM
Reviews: 120
Even if they weren't it's not a big job to replace them either.
post #9 of 10 (permalink) Old 02-13-2015, 09:44 AM
Hi mate, so did you install lo pro edge on your RG7420?
Thanks
carcass77 is offline
post #10 of 10 (permalink) Old 02-13-2015, 12:26 PM
I found this thread on metalguitarist not long ago when searching an answer for the same problem. Link to the thread: http://www.metalguitarist.org/forum/...trs7-ofr7.html
Intortus is offline
Edge III swap for another Edge model trem? lespaulreedsmith All Other Guitars (including Prestige) 39 12-21-2017 06:11 PM
WTB or Trade: A Chrome Edge, or swap for Cosmo Edge. clar-v-d Classified Ads: Guitars and Gear 0 11-17-2011 06:27 AM
JS100 bridge swap??? Edge Pro / Edge Pro II n7uqa Ibanez JEM, UV, JS & Other Signature Models 8 06-04-2009 11:35 AM
Edge Pro II swap into an Edge Pro trem??? Flame_Virtuoso_6688 All Other Guitars (including Prestige) 0 07-18-2005 06:01 PM
