Hello everyone,
This is my first post ever. I have gone through this entire topic (Edge III has been giving us trouble for 11 years and 26 forum pages).
One thing is clear: The direct replacement for Edge III bridge is the Edge Pro bridge, no modifications needed whatsoever.
But let's face it: It is 2018, the Edge Pro bridge has been discontinued for quite a while now, and you can only get to see them on ebay. The ones that I've seen are quite worn out. Ibanez Rules has a couple new ones for $270 but I want to explore more options... Ultimately I'd end up buying one of those
I've been looking for a low profile floating bridge to replace the Edge III bridge in my RG, hopefully one that may require NO heavy modifications to my guitar (no drilling, no sanding, no woodwork involved) and I have stumbled upon two possible options:
1) Floyd Rose 1000 Series Pro (Like the one in the EBMM JP16)
2) Floyd Rose Pro
Looks like these two, when installed, they go flush with the body and the only modification that they would require is to get shims in the saddles to adjust to the Wizard II neck radius. But there is still some things that I'm worried about:
1) The distance between the posts in the Edge III cavity will fit the distance for the posts in any of these bridges?
- By checking the dimensions in the FR site, both of them have a post distance of 73.91 milimeters.
2) String spacing: Taking this in consideration, I'm leaning towards the 1000 series since the string spacing in the 1000 series is the same as in the Floyd Rose original, which I understand that works fine with as a replacement for Edge III, but I understand that the FR Pro has a better quality than the FR 1000. Again, I would like to have a balance between quality, low profile in the bridge and compatibility with the Edge III cavity.
- Does anyone know the string spacing in Edge III? I've been looking for proper Edge III dimensions EVERYWHERE, with no fulfilling results. I'd have to measure the Edge III myself, but not having a caliper gives room to hell of a lot of uncertainty.
Thank you!
