Ok so im fitting two BKP's into my rg350m-ye next week.
it is H-S-H (im leaving the middle single coil as is for now).
anyway, im thinking of swapping out the tone/volume pots for a push/pull pot, one for each humbucker to change it from series to parallel when pulled out.
i've found this:
but i dont know how to implement it. Using the DIMARZIO side as an example, i assume the + output will act as red, and the - will act as green, and both will be wired as usual, but then where does the black/white wire (which would be connected together and attatched to the switch in typical RG wiring) go?
if someone could provide a wiring diagram for this, it would be greatly appreciated!
i've found this:
