Original Edge Trem - Can the radius be changed?
3.7K views 4 replies 4 participants last post by  Monsta-Tone
#1 ·
Can the string radius be changed on an Original Edge tremolo?
#4 ·
You can buy specific shims that would fit an OFR or Edge, for a rounder radius you woiuld add some height to the D,G. A, and B strings depending how much adjustment is needed, you can also use pieces of foil or another material that will give height to the saddles...
It's not too difficult really and can easily be changed or added to if you need more height!
There may be some usefull info on rich's Ibanez rules site but im not 100% on that you could also cut shims yourself I believe many manufacturers just use some copper placed under the saddles that need raising...
I've have taken plenty of ofrs and alo pro apart so it's not difficult to reassemble, just be carefull with the metal washer on the saddle bolt screws as they can fall down,,,,
