hi there.
i have a question about sanding a 430mm frets (ibanez prestige 3120TW - 2003 Edge pro).
i saw on stewmac nice radius sanding blocks, but 16.9" (430mm) is not supported there.
anyway, i've made some measurements and the difference of level between 16" and 16.9" is only .003" (0.076mm), wich it seems very small number to me..
this is the small problem thinking that you can use also a flat sanding surface
but stewmac also sells a nice handheld fret press (jaws) for refreting.
http://www.stewmac.com/shop/Fretting_supplies/Pressing/Jaws_Handheld_Fret_Press/Jaws.html
the problem is that this tool does not support 16.9" either. has anyone tried the 16.9" radius with the 16" press insert? it should work well..
