Replace Cracked JS100 Neck with Jem neck
1 reading
6.8K views 15 replies 11 participants last post by  fettouhi
#1 ·
My JS100 (1994 black model) has a crack in the neck and I got it checked by a luthier who confirmed it is unrepairable so I need to replace it. I thought that placing a Jem Neck in it might be cool but I have read that you can only buy the exact same model neck from Ibanez and you have to send the old one in. I have some pictures of my js100 here of this.
Any thoughts on this would help, what would you do in a situation like this?
#8 ·
ok the feedback/ideas has been welcome from everyone....
It does extend up towards the tuners slightly as you can see in the pics although the length of the split is not highlighted so well in the pictures. It's also split in three places (by the middle of the holes, top & below each hole)
I checked out that great tutorial on a split neck repair and it looks like I may be able to do this, it's worth a shot at least....
I have one question with repairing this, Would I have much problems putting the neck back on the the body again? I guess I will have to get the truss rod all set up correct plus all the intonation setup can get tricky....
With the Jem neck question, well I will have to forget that, it was just an idea.
My plan now after thinking about it is to try to fix it first and if that doesn't work too well then I will try to see if I can get hold of a neck on eb or maybe try to sell it this like it is as "needing repair" - I would most likely take out the dimarzios for my next guitar though...
#10 ·
I'm not even sure, I do remember bumping it against a wall a few months ago so maybe it was that but I never noticed it until recently (about 3 weeks ago). Maybe it was just from the changing weather patterns here in Aussie?
I have been reading some other threads like this one here, it seems some people replace this neck if they want to improve it so maybe looking at another neck like the one used in the js1000 or an aanj neck ( I have no idea what this is yet) could be an option if the repair job doesn't work.
