Seymour Duncan TB4 w/sustainer wiring help???
1 reading
5.5K views 3 replies 2 participants last post by  Vim Fuego
#1 ·
I just purchased and installed a SD TB4 in my Fernandes Dragonfly Elite. I installed it with a dpdt on on on switch for series/parallel/single operation. Each mode worked, however, when I switched to the bridge/middle selection, it sounded out of phase. So, I switched the green wire with the black wire, and the red wire with the white wire (wiring diagram attached). I'm still getting three different sounds which seem to be series/parallel/single-it seems to be in phase with the middle/bridge on, however, it doesn't sound quite as good (bridge alone) as the first time. I don't know much about wiring, so I don't know if it is exactly the same or if something is different now. Please let me know...
