Tell Me The Best Overdrives You've Tried
14K views 58 replies 46 participants last post by  therightjem
#1 ·
I love Overdrives and have been playing for almost 40 years.Only in the last 10 years did I get to the Best Overdrive Pedal in my endless search.
So here it is Top 5
#1 is my Handwired Black E-6 Lovepedal
#2 is my Handwired Twin Sixty Lovepedal
#3 is my Tech 21 Oxford
#4 is my Ibanez Tubescreamer
#5 Catalinbread Silver Kiss Mk2 (English version)
#1 and #2 sometimes I don't know which I like better,The Twin 60 is a GREAT PEDAL so transparent with 2 boost switches very good for Rhythmn,The E-6 is also transparent ,but really good for Metal and leads.
If you get a Lovepedal -go for the Handwired Lovepedal..... forget the price ,You only live once!!!!!!!
What are your favorites?
#19 ·
Same here! Others have come and gone over the years, but for adding a bit of a boost to an already overdriven amp for solos, nothing has been able to touch my SD-1. In front of many tube combo amps and heads over the years, and now permanently in front of my lifelong dream amp - Soldano SLO. Gives me that subtle boost and sustain I want without altering the tone of the amp it is in front of.
#9 ·
Man, I bought a used Tech21 Direct drive thing awhile back, and I sold it. It was the best overall drive I"ve found. It just had that sound of a stack without an amp plugged directly into the PA. I also used it in front of a tube amp and it sounded great on the clean channel.. I wish I'd kept it. Tech 21 stuff is good stuff..
Tim
#15 ·
For the price, I absolutely LOVE my MXR Micro Amp. Its subtle and transparent and doesn't color my sound. Its more of a "clean boost" than an OD (but sometimes boost and OD are interchangeable depending on the pedal your referring to). Gives my Egnater Tweaker another weapon in its arsenal.
Now, best I've tried but dont own...
TS808
Analogman Bi-Comprossor
Timmy
Wampler Ecstasy
#20 ·
I use my Visual Sound volume pedal (with the output gain set to max) to overdrive my amp. I used to use an overdrive, but I found that just pushing more volume has a better effect, and it's variable with a volume pedal :D
There's also a 2nd output channel, set to unity gain, on my volume pedal too, so switching the cable from output 1 to 2 disables the boost.
I've found this to be the best solution so far. But if your using your overdrive to cut out low frequencies, then i don't think this solution will work for you too much.
Toodles, Julz.
#22 ·
I had an old SD1 that was killer back in the 80's I think it was. I was playing thru a Fender Twin reverb that I had at the time that sounded great on the clean channel, and cranked espeically when I really cranked it up and then used the SD1. It was a jap made version if memory serves me..
I still say the best I've had was the American made Tech21 pedal. It had three options, but I used the Marshall option almost exclusively with my Peavey Ranger. The cool thing was, I'd get killer gain with it, but could turn down the volume knob and it would clean right up, which to me is the measurement if a pedal is good. I like a pedal to be responsive so I can dig in and get killer pings and then go to almost clean with soft picking. That's hard to do.. Anybody else use a pedal that works that way? If so, what model?
#25 ·
My current pedalboard has many drives that are quite different from one another in function and tone...
-Wampler Super Plextortion
-Wampler Pinnacle
-Freekish Blues Alpha Drive
-Marshall Guv'nor Plus
-Wampler TripleWreck
-Marshall Jackhammer
-Maxon OD808
-Boss Fender '65 Deluxe Reverb
-Custom Audio Electronics MC401
thru a Boss DD3 and EHX HolyGrail Nano for ambiance into a Bogner Alchemist.
Any tone, anywhere ;)
