I'd like to put 2 greenbacks and 2 V30's in 1 cab in an X pattern, but wired so, that I can use only the greenbacks or the V30's if I wish, by mounting each 2x12 setup to a separate jack at the back of the cab. If I wan to use all 4 of them, I's just use 2 outputs on my amp. If I only want to hear V30's I just unplug the greenbacks (taking correct Ohm's into account of course). That way I could also connect 2 heads to 1 cab.
Now what I once heard from a amp/cab builder: if you only use 2 speakers in a 4x12 setup, so the other 2 speakers are passive, the 2 passive ones would 'absorb' some compression/air pressure that the other speakers generate in the cab. This would result in a misrepresented audio effect.
When I asked him what the effect would be in an open cab (I supposed none as there is no compression effect....) I didn't get an answer.
I'd prefer to have a closed back of course. Any thoughts on this ?
Thanks
Thanks
