Volume knob placement on Jems...
3.8K views 10 replies 9 participants last post by  Drawbridge44
#1 ·
Has anyone noticed that the volume knob is in a slightly different spot on some Jems. You can tell just by looking at the differnt pictures in the galleries. On some the knob is a little farther back and closer to the nearest pickguard screw. It seems that it might be more out of the way for those people who have a problem with the knob location when it is higher up and closer to the pinky. Is this a known change or am I just seeing things?
#2 ·
I don't remember that factoid being pointed out. I'm sure it has somewhere on this site and I missed it. But, yes. My 1987 777 Models have the Volume knob much closer to the bridge than most of my others. Very Jackson-esque. I prefer it set back more. If I ever get a custom-built guitar - I probably won't have any control knobs except for the P/U selector.
Mike 777 Haug
#3 ·
I believe it changed in 1990 when the UV came along. The UV has always had the further back knob placement and I believe that's when the JEM's changed as well even the DY's I have noticed that pre 1990 they are closer to the pickup.
I like the further back position better, on my 87 DY and SK I always found the vol knob a little crowded.
original placement
Newer placement
and just as an example on even the original guitars changing
#6 ·
Rich said:
It should also be noted you cannot get replacement guards for 87'-89' Jems. The replacement guards are for post 90' style layout only ;)
Aren't those RG guards? I was under the impression that RG's had the same lay out as the old Jems. That is, I have an RG guard here which has the volume position too close to the bridge.
#11 ·
Thanks for confirming that I was not seeing things. I guess this means that I will like playing the more recent knob placement better because the knob placement on my 87' Jem DY is too close sometimes. Awesome guitar anyways though..
