That´s it. For me it´s crystal clear, nothing like a good distortion through a valve amp. Gain just for some rythms. What´s your oppinion?:argue:
Are you talking about a distortion pedal through an amp ? If you are then i have to disagree cos' if your amp is a good one like the Bogner Ecstacy, Rivera Bonehead, Carvin Legacy or Mesa Boogie Mark IIC, then why would you need a pedal to generate your distortion ? Yes, i admit that i do use a Boss DS-1 pedal with my Ecstacy and Legacy heads to overdrive the input but not to get distortion. Whatever, makes you happy i suppose cos' tone is subjective.urkoman on 3:28 pm on Mar. 29, 2002
Of course if you're using a soldano G.T.O supercharger it sounds quite a bit better...but for a 400 dollar distortion pedal it sure as hell better! I thought about using one in a legacy on the lead channel when i want to get kinda crazy... :silly:Guitarlos2 on 3:13 pm on Mar. 30, 2002
I prefer an amps gain over a pedals distortion most anyday. It really depends on what kind of amp youre using though. I have a Mesa DC-5, and I love the lead channel. It has a great rhythm sound, and its good for leads as well (although i do use a pedal to boost my signal for leads).
You just cant get the same saturated tube tone out of a distortion pedal. Its just a bunch of diode clipping, and simulated tube tone. Distortion stomp boxes are cool for some stuff, but when it comes right down to it, the amp is where its at![]()
I strongly disagree...listen to Jeffrey's track. If Im correct he's just using his amps gain and it sounds pretty heavy to me. Same with amps like bogners and VHT's. If you're using a 50 watt plexi maybe the overdrive isn't heavy enough for leads, but any good modern high gain amp should have ample gain in the distorted preamp channel. I use ds-1's and such for db boosts for lead work, but it sure as hell isn't for the gain. But like I said, a tube driven o.d pedal like the supercharger should be good. But or course the supercharger is basically the gain section of the slo 100's if Im correct.urkoman on 3:28 pm on Mar. 29, 2002
Why do you use the ds-1 to boost your signal for solo work? Why not use an EQ pedal of some sort?? Wouldn't ds-1 affect the nice distorted tone from your amp ??I use ds-1's and such for db boosts for lead work, but it sure as hell isn't for the gain.
I thought about it once...but i haven't. Only guitar and my wah pedal before the pod. i find that doing some tracks with the pod can get really muddy...so i would never do that.RSVampire said:anybody ever pop pedals in front of a Line 6 Flextone or POD?
No...it doesn't hurt it. I usually put the level above 12 o'clock for a little boost. It helps drive the preamp tubes more to get a little more compression and saturation. I'm not really using the gain knob...its usually all the way off. (unless im going for feedback...etc.) As far as an eq pedal vs the ds-1...$80-$100 e.q pedal vs. $40 ds-1 that does the job perfectly well. HMMMMM?? (hey, vai does it) AND, a ds-1 or other lower gain pedal can help control your tone on stage to compensate for environmental effects on your tone. (ie...floor material, walls...people...etc etc etc.) :0Frankie said:Why do you use the ds-1 to boost your signal for solo work? Why not use an EQ pedal of some sort?? Wouldn't ds-1 affect the nice distorted tone from your amp ??I use ds-1's and such for db boosts for lead work, but it sure as hell isn't for the gain.![]()
Yes it is absolutely possible. There are lots of high-gain amps out there that will accomodate that very need. It's just that it's nice to have an overdrive pedal set for a clean boost to fatten up the lead tone with a swipe of the foot.Courjan said:Hey guys,
Is it really possible to get a distortion tone for lead playing (lots of sustain) without a pedal overdriving the amp?
PS : I'm new to tube amps
