I just purchased my first 7-string (RG7620) recently and I am looking to replace the pickups. I have been exclusively playing Hamer Californian Elite U.S.A. models on stage with my band (I have 4 of them), which are awesome guitars. I own several other guitars also, but these are my "work horses". I play music professionally in a modern rock/hard rock/progressive rock/metal band (Pantera, Alice in Chains, Metallica, Rush, Queensryche, etc.) All my guitars are equipted with the same pickups and I play through a rack setup with a Rocktron Pirahna tube pre-amp, Alessis effects racks, then into a Mesa 2:90 power amp. This allows me to be able to switch guitars at any time for any reason and still retain my sounds. And have the ability to dial in any new tones I might want which will work with any of the guitars. I have the Seymour Duncan Invader in the bridge position and the Seymour Duncan Cool Rails in the neck postion on all of them. Awesome tones are available with this combination (not muddy at all on either pickup). The SD Jazz neck pick-up is my favorite for the neck position, but since it's a humbucker design and my Hamers used a single coil sized pick-up in the neck position mounted at an angle, I used the SD Cool Rails which are very close to the SD Jazz pick-up. I've been thinking about putting the Invader 7-string in the bridge and the Jazz 7-string (Seymour Duncan) at the neck. But I have also been looking into the EMG 707 pickups. Does anybody have any experience with the SD's that I have in the RG7620 vs. the EMG 707?
Thanks, Mike.
Thanks, Mike.
